Rear end swap
Old 01-15-2018, 11:34 PM
James Johnson
James Johnson's Avatar
Question Rear end swap
I have two mustang one a 1991 lx the other 1996 gt. What I'd like to know is ;
1)Can a rear end from a 1991 Fox body fit under a 1996 gt?
to make a long story short, my plans for the build have changed for the 91. When I started on the 91, I replaced shocks, springs, control arms and gears. None of this I'll be needing know because I'm building the 91 to race.
The 96 I'm putting a coyote in and I want to update the suspension. So can I put the 91 rear end under the 96 stang.
Any help would be greatly appreciated.
James Johnson is offline
Old 01-16-2018, 09:52 AM
Buck Sergeant
Buck Sergeant's Avatar
Default Rear end swap
James, hope this helps you out. Most factory Solid Axle (Live Axle) Mustangs from 1979-2004 are equipped with the standard 28 spline axles whether it be 4 lug or 5 lug. 2005-2014 Mustangs are equipped with 31 spline axles which are about 30% stronger than the factory 28 spline axles making them a popular aftermarket upgrade for 1979-2004 Mustang owners. Swapping over to 31 SPLINE axles will require the use of a 31 SPLINE differential to function properly. These are great axles if you plan on taking your Stang to the next Level!
FOX LENGTH AXLES VS. SN95 LENGTH AXLES
79-93 Mustangs - 29 3/16" long rear axle.
94-98 Mustangs - 29 31/32" long rear axle.
99-04 Mustangs - 30 11/16" long rear axle.
Buck Sergeant is offline
Old 01-16-2018, 12:34 PM
Derf00
Gentleman's Relish
Derf00's Avatar
You will have to take a look at the mounting points of the Axle between the two cars. A lot of the guts like the pinion gears, seals, and bearings can go back all the way to 1979 but the complete axle with pumpkin (the shell) may not be interchangeable. The control arms are the biggest difference between them. Fox bodies are quad lower control arms vs the SN95+ are single arm on each side. I'm not familiar with the upper control arm differences between fox bodies and SN95+ models.
Derf00 is offline
Old 01-16-2018, 03:31 PM
Buck Sergeant
James, as far as I know, the 8.8 rear ends are mounted the same from 1979 to 2004. If you are putting a coyote in that 96, I would strongly recommend installing lower control arm brackets with a "cross tube" tying them in. Of course, all rear end components must be updated to 31 spline specifications, and adjustable. Don't forget your c-clip eliminators.
Old 01-16-2018, 04:21 PM
Buck Sergeant
James, I may have given you some misinformation. Here is the new news. The rear end is the same from 94-04. The 99-04 rear ends are about 1.5" longer so you'll have a more flush look on your wheels, but it still has the same bolt set up. You shouldn't need anything other than the rear end assembly, pretty straight forward swap. BUT, I forget you are going from 91 to 96. This new information makes it doubtful the 91 is a bolt-in with the 96.
Old 01-16-2018, 08:34 PM
88Mach1
88Mach1's Avatar
The 91 rear will fit just fine as long as you swap the 96 axles and brakes onto it.
88Mach1 is offline
Old 01-17-2018, 06:42 AM
Buck Sergeant
88Mach1, thanks for the clarification. It's good to know someone will catch my back. Again, thanks.
Old 01-18-2018, 12:05 PM
wbrockstar
wbrockstar's Avatar
Default Axle Length Difference
I believe the 94-98 axles are 3/4" longer than the Foxbody axles plus they're 5 lug vs the Foxbody 4 lug.This is one reason why you must swap axles if using a Foxbody 8.8 in a SN95 since Foxbody axles are 3/4" narrower than SN95's.
Last edited by wbrockstar; 09-27-2023 at 12:29 PM. Reason: Had to correct an error in the info
wbrockstar is offline
Old 01-19-2018, 08:46 AM
Buck Sergeant
wbrockstar,88Mach1 and Derf00, you are right on the money. The first thing I did after dropping my 331 stroker in the 1987 foxbody was to install,in the 8.8 rear; 31 spline high grade, five lug, axles, new trac-lok 31 spline carrier, with carbon fiber discs, C-clip eliminators, and replaced ALL rear suspension items with STEEDA adjustable replacement items. Also,just to be safe, a 3 quart ford performance differential cover with 75-140 ford synthetic oil and 4 oz of friction modifier. I went a little crazy on the rear because I am installing a 200 hit of juice. Everyone's information is going into my log book.
DaBears1983
02-11-2012 02:19 PM
sv650lex
05-24-2011 08:59 AM
Ninety5PoloZ
09-08-2009 12:36 PM
jeffdavis411
01-20-2008 07:17 PM
GT 281
02-04-2007 04:45 PM
Quick Reply: Rear end swap
