93 5.0 Mustang
Old 08-02-2018, 06:32 PM
Rudy0131
Rudy0131's Avatar
Default 93 5.0 Mustang
Hi I want to know the normal running tempature of a 93 5.0 but with the a/c on
mine is 186 with a/c on
what’s the normal?
whats the normal tempature when sitting parked while the a/c on too
mine is 200
Rudy0131 is offline
Old 08-03-2018, 08:04 AM
GT Nate
GT Nate's Avatar
coolant should boil around 256 - 275°
If your temp gauge is in the Normal range you're fine. My 93 Tbird with the 5.0 would get to the upper part of Normal in stop & go traffic, but never overheated.
From google search, you don't really need to worry about the lower coolant hose, it's the upper one which gets all the stress.. make sure its' in good shape.
If it's been a while since any coolant flush, I'd suggest going to Goodyear to get it done. they charge around $90 for a pro flush.
Good luck amigo.
Also make sure your coolant fan (which is probably either electric, or directly connected to the engine spins freely when cold. On my Bird as the engine heated it'd heat an element in the fan which made it spin faster... Not a perfect design...but that was in the 90's)
GT Nate is offline
Old 08-03-2018, 07:01 PM
Rudy0131
Rudy0131's Avatar
So that’s the temp when the a/c is on?
Rudy0131 is offline
Rudy0131
Rudy0131's Avatar
Default My car
Good luck amigo.
so that’s the temp when the a/c is on?
Rudy0131 is offline
Old 08-04-2018, 07:28 AM
GT Nate
GT Nate's Avatar
I think it ran a little cooler with the ac on as the fan was more engaged....but it REALLY depended on getting back to a good speed to keep air flowing through it... once I was back up to speed the temp would go back to mid normal.
Hot Midwest summers do that.
GT Nate is offline
Old 08-07-2018, 07:35 PM
Rudy0131
Rudy0131's Avatar
i get 205 or 210 in traffic
like 130 degrees outside
0mph traffic
like waiting in line
is that normal ?
with a/c on blast
Rudy0131 is offline
Old 08-07-2018, 07:37 PM
Rudy0131
Rudy0131's Avatar
This is my 1979 Ford with a 93 5.0 mustang
Rudy0131 is offline
Old 08-16-2018, 05:19 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
it is going to creep up when at a stop. 210 is fine though.
TrimDrip is offline
Old 08-20-2018, 08:59 AM
wbrockstar
wbrockstar's Avatar
On the Foxbody,there was a ground strap mounted between a lower intake bolt (rear) or cylinder head thermactor pipe bolt (rear) & the firewall.Its the ground for the ac clutch,interior/exterior lights,alternator & the gauges.If this ground is loose,corroded or missing,it will cause the temp gauge to
increase when turning accessories on like
the ac,blower fan,headlights,etc.The Foxbody used a flat braided ground strap at this location or you can use a short 4ga battery cable in its place instead.You wanna have a minimum of 3 main grounds for the 302 HO efi engine,in order to make a complete ground loop.
1) 4ga cable from the neg battery post to the engine block.......
2) Flat braided ground strap or 4ga cable from the intake/cylinder head/block to the firewall.......
3) 10ga wire from the neg battery post to the fender apron and another wire from this fender apron location to the black/green wires (that lead to pins 40 & 60 at the ecm)
on the main harness.
** Note ** If you're using the oem style neg battery cable,with the included 10ga wire/pigtail/tubular connector,the pigtail can simply be bolted to the fender then the tubular connector can be plugged in to the
tubular connector on the main harness.
This ground is imperative for an efi application since its not only the ground for the ecm & the sensors,but its also the one that completes the ground loop.
wbrockstar is offline
slowmotion
09-27-2013 10:29 PM
Duncan_GT
01-27-2013 12:42 PM
Marunos
10-11-2008 12:59 PM
norcalpit99
14
04-13-2007 08:47 PM
lead09
09-08-2006 12:43 PM
Quick Reply: 93 5.0 Mustang
