1990 Ford Mustang 5.0 Loss of Oil Pressure when accelerating
Old 04-22-2019, 03:06 PM
MUSTANG5L
MUSTANG5L's Avatar
Default 1990 Ford Mustang 5.0 Loss of Oil Pressure when accelerating
Hi there
I’ve recently rebuild my 90 mustang 5.0. Was a 302 and was bored 30 over. Primed the oil pump before start up and put about 30 miles on the engine and then noticed my oil pressure gauge kept dropping to zero when I accelerated and on decel and idle it came back up. Brought the vehicle home and noticed some noise from the valve train assuming the oils not getting there? I removed my distributor to look at the shaft and couldn’t tell much. Now I’m wondering if I should run the car again with a gauge hooked up or if I should look towards dropping the oil pan and inspecting the oil pump? I replaced the pump with a normal oe spec melling pump and pick up tube.
MUSTANG5L is offline
Old 04-22-2019, 03:33 PM
drhoward
Penis Mod Erator
drhoward's Avatar
I'd try checking by hooking up an aftermarket gauge just to be sure.
drhoward is offline
Old 04-22-2019, 04:06 PM
MUSTANG5L
MUSTANG5L's Avatar
Okay I will do that first. I do have a fuel pressure gauge that measures 0-100psi. Would that work to test oil pressure aswell?
Old 04-22-2019, 05:09 PM
drhoward
Penis Mod Erator
drhoward's Avatar
I'm honestly not sure if it will work or not, I had issues with mine a few years ago and I just bought a cheap gauge to check it. I think it was only around 20 dollars or something.
drhoward is offline
Old 04-22-2019, 09:06 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
yeah, for sure check it with a mechanical gauge. they are pretty cheap at the parts store.
i guess the thrust bearing is good? I have seen that cause a loss of pressure on different type engines. I assume that may apply to the 5.0
is the car an auto or manual?
TrimDrip is offline
Old 04-22-2019, 10:21 PM
MUSTANG5L
MUSTANG5L's Avatar
All the bearings were replaced when the motor was out. Car is a 5 speed manual. I will perform a oil change tomorrow and place a gauge and measure oil pressure
Old 04-23-2019, 02:24 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
make sure you didn't blow an oil galley plug out.....there behind the timing cover.....right around where the cam slides in. that will cause the issue you describe. Had it happen more than once, now I tap those holes vs the press in plugs
mjr46 is offline
Old 04-23-2019, 07:46 PM
MUSTANG5L
MUSTANG5L's Avatar
Should I pull the timing cover out and inspect first?
Old 04-24-2019, 10:52 PM
MUSTANG5L
MUSTANG5L's Avatar
Any guidance please? On if I should start by draining the oil and cutting open the filter to inspect and filling new oil and check pressure with a gauge or should I remove timing cover and inspect the oil gallery plug?
Old 04-25-2019, 09:54 PM
MUSTANG5L
MUSTANG5L's Avatar
Anyway I can confirm I have a blown oil gallery plug without having to remove the timing cover?
Quick Reply: 1990 Ford Mustang 5.0 Loss of Oil Pressure when accelerating
