Ticking Noise from underside
Hey all,
So, i recently replaced my stock exhaust with an MBRP Street Series Catback... 3" system with a 4.5" tip. No problems, car runs and sounds fantastic. Fast forward a couple of months, and two weeks ago, i took the car to the dealership for a regular service. All warranty issues resolved, and service completed.
I get the car home, and now at low rpm, low load (the only time i can hear anything else), there is a ticking noise coming from under the car. I have a pretty good ear for these things, and i can determine with almost certainty that it's coming from the stock side of the car (up to the cat). It almost sounds like the same ticking you hear after you turn older cars off, if any of you can understand what i mean by that. But it started directly after i got the car back from service.
In any event, do any of you have any insights about this? It goes back to the dealer tomorrow for a fuel filler issue (I can't seem to keep the fuel nozzles in the car without sitting there with it, and even then i have fill issues) and a small interior replacement part. I'm having them look at this issue too. I took a video to prove it to them (aside from my service writer, who i've built a working relationship with over the years, the dealer is big on the "we can't replicate the problem" argument).
Anyway, let me know.
Thanks,
-J
Thanks,
-J
Thoughts?
No rattling at the tailpipes (no idea what the dealer was talking about). But upon further investigation, i have localized the ticking right under the engine bay. No idea what it could be. The ticking is not uniform or rhythmic. the same kind of random pattern you get when the first few kernels start popping in the bag while microwaving popcorn, if you catch my drift.
Any ideas?
There was an exhaust alignment procedure for 05-07's. Might be the same for yours?
http://iihs.net/fsm/?dir=309&viewfil...0Alignment.pdf
SAME ISSUE!
I just recently took my 17' GT (7500 mi) to the dealer for the same concern. Inconsistent rattle tipping into the throttle between 1500 and 2500 RPM. I've personally isolated the noise to the rear end of the side of the block. Cannot 100% tell if it is in the clutch area or if it is indeed in the block. Apparently many have complained about the same issue and have found either cylinder distortion or defective piston wrist pin. Waiting on the dealer to give me an answer in the next couple days.
