Another 2015 GT Misfire problem
This misfire is becoming a common problem. Purchased this GT Nov.30/15 with approx. 3800 miles[5400 kms.] on it. The engine light went on around Dec. 18/15. As I was at a service center getting a oil changed I had them run a scan and this what came up:
p0018-cam position sensor
po300-random misfire
p0307-cly. 7 misfire
p0306-cly. 6 misfire
p0316-misfire detect.
Had them clear the codes and the next day on came the engine light.
Took it to the Ford Dealer. They said that it had been at another Ford Dealer in Oct. twice for engine codes. The Service writer said that the new codes when I took it in showed it happen from cold starts.
As it was close to Christmas Eve they did not here back from Ford as to how to correct the problem.
At least Ford is aware of the problem before I purchased the car used.
Car goes back on Dec. 30/15 to check for codes and what Ford has to say.
Will advise then, also look for answers from the other 2 members that have the same problem.
