Auto Transmission Issue Mustang 2011 GT5.0
Does it do this with Traction Control completely turned off? Hold do the TC button for about 5 seconds.. and then see if it still happens. When TC engages, it cuts power and applies the brakes to the spinning tires... even in Sport Mode.
A follow up question, what rpms are you talking about when the revs are very high?
I do think there is something wrong with your car, just don't know where to tell you to look yet. One thing you can check, open the airbox and remove the filter and look in there to see if thee is something clogging it up. I dug some leaves out of mine, i saw a post where a guy said an empty cigarette pack was in there.
That sounds like the transmission is immediately upshifting, if it isnt up shifting it sounds like trans is toast.
I think you maybe onto something as I turned off TC and gave a it a run, by the time I hit 70mph i was at 7000rpm and released the pedal and immediatelly dropped to 4000rpm but I could actually here the transmission shifting down....................
Jskeezy84
09-08-2015 01:40 AM
0509, 2011, 50, auto, boss, install, issues, kit, mode, mustang, slip, sport, syncrinizing, transmission, trasmission
