2011/2012 Aluminum V-8 - OIL
Did a quick search but found little pertaining to the GT's Aluminum V-8.
Other than personal preference, is there any factual data out there on the benefits of using one makers FULL synthetic oil over another in the GT V-8 engine??
I'm not talking about oil weight, just one brand over another.
Thanks
Thanks
there are a few oil debate threads floating around the site. basically, modern oils are far superior to anything they had 30 years ago and even 15 years ago. it's one reason they now say you can go longer between oil changes.
but no, if you go full synthetic it really doesn't matter which you use, some people think royal purple is awesome, others think its the worst thing you can do to your engine. i've been using mobil 1 in my 4.6L.
It really doesn't matter though, comparing the 4.6 sohc 3v to the 5.0 dohc 4v they may be different engines but the oil works the same way.
I'll say the different oils will give you superior gas mileage(however tiny bump, not worth worrying about), but they achieve peek verscosity and a lower temp. doesn't mean it wont work as well, but it was debated heavily for awhile the 5w20 vs 10w30... you'd have to have a very accurate temp gauge and see what your oil is running at to determine the "best" oil, but i dont think its worth the time/effort.
and anyone that claims using a different oil gives them noticeable performance is delusional.
I believe that as long as you follow the manufacturer's recommended type, viscosity, and schedule of oil/filter changes any brand that meets the most current API standard will do.
Here is a reference:
http://www.carbibles.com/engineoil_bible.html
NEVER said noticable bro... Just an "increase" which has been dyno proven by RP and others.Typical RWHP gain has been 5-7 hp IF it is used through out whole driveline. Motor alone will do nothing for the dyno results.
Waiting on this to turn into an amsoil love fest lol.
Honestly any relatively good quality oil should be absolutely fine. I've run amsoil through mine for my first interval and in the future plan on using Pennzoil Ultra on my next change. Popular oils are Royal Purple, Amsoil, and Mobil 1 (by far). I know the whole "fully" synthetic debate will come up in here, but unless you plan on running your engine for a million miles, you're going to be absolutely fine up to 200k with any "fake" synthetic as well. "Fake" includes things like Pennzoil Ultra, Mobil 1, Castrol/Valvo Synths etc, and "Real" includes RP and Amsoil. But getting real, any of those will run great through your engine.
each dyno run can be +/- up to 10whp, i don't buy, never have, never will, it doesn't even make any sense why it would give you more power. I've read why people think it would but it doesn't make sense.
Thanks for the feedback . . . BUT
While we are talking oil, what about the oil filter you use.
Regardless if you use RP, Mobil 1, or whatever, do you normally stay with the Ford OE oil filter or are you using what comes off the shelf where you get the oil changed or if you DIY, do you stay with Ford brand or something else??
Again, I am talking street driving here.
