Help with wheel hop.....Please! - Page 2 - MustangForums.com
5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Old 06-30-2011, 06:48 AM   #11
Big_T_Judge
Big_T_Judge's Avatar
Quote:
Originally Posted by Jiggy_One View Post
The only thing that will really stop your hop is an upper control arm. The lowers will also help, but will not stop the hop by themselves. No matter what anyone tells you, the upper is the only part that will stop the hop. Its the only part that controls the axle twist. Not the lowers. Springs can help too, but again, not alone. Get the upper.
Thanks for the info. Just pulled the trigger and ordered the UPR upper and lower control arms http://www.uprproducts.com/mustang-c...stomer-reviews I Liked the che's, but they were out of stock. Will let you guys know how the UPR's work out.
Big_T_Judge is offline   Reply With Quote
Old 06-30-2011, 03:53 PM   #12
Mishri
Mish-ogynist
Mishri's Avatar
That should cure it, kind of weird on the s197 how some people have wheel hop on stock tires, and i've never had it on my '07 or '12 even with drag radials. although I also can't rev mine past 2,000 on the stock stall so that could be part of it.
the last thing try after those 2 is relocation brackets, but i'm sure those 2 things should solve your problems.
Mishri is offline   Reply With Quote
Old 06-30-2011, 09:28 PM   #13
SpartaPerformance
SpartaPerformance's Avatar
Should've gone with C.H.E. much better quality.
SpartaPerformance is offline   Reply With Quote
Snow performance stage 2 MAF boos cooler install jwog666 Pipes, Boost & Juice 6 01-07-2018 07:16 AM
Chassis wiggle when off throttle? UrS4 S197 Handling Section 10 10-03-2015 06:23 AM
20 inch Wheels a mistake on 2015 Mustang GT? mungodrums The New S550 2015-2019 Mustang 10 09-28-2015 10:54 PM
Polished wheels folivier Detailing 0 09-26-2015 02:28 PM
2 or 4 wheel alignment? lincolnshibuya V6 (1994-2004) Mustangs 1 09-24-2015 10:46 PM
2011, 2012, arms, control, extreme, forums, gt, hop, jm, joint, lower, mustang, rear, wheel, wheelhop, work
Featured Sponsors
