Oil separator for stock 5.0?
I have seen a few people that have oil separators on stock 5.0 so I called a local shop in town to order one and have them put it on. They told me I didn't need one unless I was going to use a super charger and it would only be for looks. Does anyone running an oil separator on a stock 5.0 catch any oil in thier separators, and are they right the you only need a separator if you have a supercharger?
They actually catch oil, in a thousand miles or do, people have reported their oil catch cans catching as much as a table spoon of oil. And this is on NA cars, no FI at all.
That of course is oil that would otherwise contaminate the fresh fuel air charge and also add to air pollution. For you, the power loss might be minimal, but over time, oil could build up on your plugs, contribute to carbon buildup in the cylinders, get into the cats and raise their temps which could eventually lead to melting the cat elements, and other possible bad stuff.
These are just some things off the top of my head, but I could be wrong.
Anyone else more knowledgeable of what oil contamination does when it enters the combustion chamber, please chime in.
Not sure. I put mine on the passenger side as well. That's where all the damn oil is pushing out. I inspected the drivers side tubing and intake - she's dry and clean, so no need for one on the drivers side.
I edited this to denote that mine is a v6. I don't want to mislead anyone since this was posted in the 5.0 section.
I could be wrong but Im willing to say it's due to the vaccum of the motor. The way its designed in essance. Anyone who knows better please chime in.
The same thing occurs on S/C vehicles, but the vacuum increase is great enough to pull oil on both sides, eliminating any real flow between the drivers and passengers side PVC vents.
thats why you only need one side.
to check which side you put it on, look inside each of the lines. whichever side has the oil, thats where you put the separator.
