H-pipe and Cats
#21
60 foot should be 2.0 or lower, that would take atleast .427 sec off your 1/4 mile.
if you can get a 2.0 or lower 60 foot, and trap 114+ you should be mid 12's
a trap of 114 is definatly capable of 11's if everything goes right imo
Is your spare tire in the trunk? if so, removing it could remove like 40+ lbs from the car. Also you should have about 1/4 tank or less of gas.
whats your altitude?
#22
My biggest problem right now is that I'm not getting any kind of traction. When I came off the line I was spinning, I feathered the gas before I went into second and I should have just gone into second. I spun through second and into third I spun a bit also. Once I was midway through third and into fourth I was good to go. I was runnin on less than a 1/4 tank of gas and my spare tire was in the trunk. I'm going back down Friday and I'll take it out this time. I'm not sure what the altitude is here.
09-24-2015 09:18 PM
JDWalton
09-24-2015 08:47 PM
trashxtrash
09-20-2015 10:49 PM
