Wheel hop during burn out
LCA's will be the first step, most people are cured of wheel hop with just that. or if you are feeling froggy and want to spend more and do more, get the UCA's too. LCA's are usually the cheap/easy fix though, most people don't need the UCAs.
You're telling me that you launched your car at the track at 5200 RPMs... when I launch at the track I launch at about 1800 and I don't dump the clutch, but I'm on street tires too. The only time I actually "dump" the clutch is when I'm doing a burn out. I will definitely be buying some LCA's within the next week or so and I will most likely order them from UPR.
^^agreed
Whats more recommended between LCAs or Traction Bars ? i get wheel hop like CRAZY on wet/dry roads.. main issue is i have bald tires, but was told i need LCAs or TBs .. just not sure which are better ? im new to the forum and mustangs ! only had my 87 GT 5.0 for about 2 weeks now .. id appreciate the help !!!!
Steeda has a pak specifically for Wheel Hop, conveniently, its called Stop the Hop.
http://www.steeda.com/store/steeda-s...d-mustang.html
For 2011-2013 these parts would apply:
http://www.steeda.com/store/steeda-mustang-chrome-moly-lower-control-arms.html"]http://www.steeda.com/store/steeda-m...trol-arms.html[/URL]
http://www.steeda.com/store/steeda-m...ntrol-arm.html
If you are running over 500 HP then I would recommend these LCA's:
Let me know if you need forum pricing or any help putting a package together.
Best Regards,
TJ
Best Regards,
TJ
lincolnshibuya
12-08-2015 04:37 PM
mungodrums
09-28-2015 10:54 PM
