Supercharge or turbo?
#22
My 5.0 is currently off getting a custom turbo kit. I was also on the fence with which to go with, but I just LOVE turbos. There are advantages and disadvantages to both, obviously, and the debate will never end. It just comes down to personal preference. There ARE a few ways to get around turbo lag though.. I'll let you know how it goes when she's all done and tuned.
#23
Turbos are only 'dogs' if the designer spent little time calculating sizing the compressor and turbine and instead just grabbed the nearest one and made it work. People seem to think turbos are some big mystery but it doesnt take much work to find the right turbo for your application. A good sign a kit wasnt designed well is when it doesnt spool until 4k+.
#24
Ahh I missed out on this thread. to throw what i've seen out there.
on the 5.0 the fastest stock engine cars have superchargers, (fastest in the 1/4 mile) every turbo car ive seen/heard of has gone boom past 550whp, yet some 5.0s are holding 700whp with superchargers. This was something I also noticed with turbos on the 4.6L, a lot of people were blowing up at 450whp with a turbo. How it builds power and where and the heat all play a role and it seems that these engines can't handle it w/o getting forged internals.
On the Mustangs supercharging has been the way to go on the stock block. If you are getting a built block for gobs of power I'd get a turbo. when discussing which is better psi is irrelevant, how much power it can put out and how well it performs in the 1/4 mile and how it drives down the street will tell you a lot more about it. yes, turbos are more efficient, but that really doesn't matter when your engine can only handle 550whp with the turbo compared to 650whp with a supercharger. I'd speculate the reason the turbo's tend to break engines is there is very little boost going in then suddenly you are at max boost and it's just too much strain on the internals at that RPM... but i'm just making stuff up now
#25
Yeah I'd tend to agree, if you are building the crap out of the motor, then the turbo is a cool setup. Since most people just want to bolt something on and cross their fingers though, I'd stick with the superchargers myself if thats how its going to go down...
#26
#28
#29
Turbos can be topped out more revs just won't pump more air. They start making heat chopping up the air. If more air is needed put a bigger turbo on the pressure drops but more air is pumped but it also takes more revs to get the exhaust energy up to push the turbine.
#30
I'm on the fence with this as well, but I can say that a friend of mine has a turbo on his 5.0 running 7psi....He holds off or beats a ZR1..
video from 5.0
http://www.youtube.com/watch?v=pdOnjITN9lc
video from zr1
http://www.youtube.com/watch?v=dPl7n_ftE2Q
video from 5.0
video from zr1
