11 GT Suspension question
what do you guys think? I am planning on drag racing a lot and dailying a little.... car is an 11 gt manual with brembos and 3.55s
2005-13 Mustang Race Star Dark Star Wheel & Tire Kit - 17X4.5 and 15X10
LINK
Hurst Line Lock - Roll Control Kit (10-13 All)
LINK
Barton Industries Short Shifter and Two-Post Bracket - MT-82
LINK
2005-13 Mustang Lakewood 70/30 front 50/50 rear Drag Strut Kit
LINK
11-13 MUSTANG 5.0L PRO SERIES REAR SUSPENSION PACKAGE III - UPR PRODUCTS
Includes Double Adjustable Upper Control Arm Kit, Double Adjustable Lower Control Arm Kit, 8.8 Spherical Bushing Kit, UPR Drag Launch Springs by Eibach, Lower Control Arm Relocation Brackets and Double Adjustable Panhard Bar.
LINK
2005-13 Mustang Bmr Black Hammertone Boxed Subframe Connectors
LINK
2011-2013 FORD MUSTANG UPR TUBULAR CHROME MOLY K-MEMBER - UPR PRODUCTS
LINK
2011-13 Mustang Eibach Anti Roll Kit
LINK
LINK
LINK
LINK
LINK
LINK
LINK
LINK
LINK
I'd leave off the swaybar upgrade if you're going for drag launches, because a stiff front bar will hurt your ETs.
I'd also recommend these Strange 10-way adjustable shocks & struts instead of the Lakewoods, because they let you tune the suspension however you'd like, easily with no tools, and they cost about the same as the Lakewoods.
http://www.uprproducts.com/strange-m...-strut-05.html
http://www.uprproducts.com/strange-m...-shock-05.html
^^you'll need FRPP GT500 strut mounts with the lakewoods or the Strange struts.
Also, you'll need a rear swaybar relo kit for those 15x10 rear wheels:
http://www.uprproducts.com/mustang-r...on-kit-05.html
That's a pretty solid setup for max launch grip!
awesome I am glad you agree. Yeah the swaybar relo kit is in your package deal. It says it comes with basically everything. hmm I will have to think about the strange struts.
what are opinions on the eibach drag launch springs? anyone suggest anything else?
Anyway, another interesting factor to mention about the Drag Launch springs rather than the Pro springs, is that the Drag Launch springs have a more comfortable ride. They're definitely the way to go, unless you're into high speed cornering.
I believe what he is trying to convey is the thought about torsional rigidity; well, rigidity as far as a the engine causing flexure on the chassis by putting a longitudinal torque.
A 4 point brace will help some to give more rigidity against this flexing, but your thoughts are right: a cage with more points and more bars that go across transversely is more rigid.
My thoughts however is that the S197 chassis is considerably more rigid than the SN95 chassis and even more so than the Fox body chassis. The S197 has so much rigidity that I think modders have confirmed that the stock S197 chassis is more rigid than an SN95 chassis with subframe connectors.
If anyone can recall where this article form one of the Mustang mags, please link; I cannot remember where it was written.
Just a guess on my part, but I doubt that you would need any sort of additional rigidity over the stock chassis until you break 550ft-lbf, maybe above 600ft-lbf. Hell, even the 2013 GT500 uses the standard S197 chassis but adds additional rigidity with an engine bay tower brace.
Someone correct my guess where I'm wrong, I cannot remember the exacts.
I think it was in 5.0 Mustang Magazine's huge write up on the S197 chassis. They said the torsional rigidity was around 1,000% stiffer than the Fox chassis. I know I've read that the S197 is stiffer than a Fox on a 6-point rollbar. I'd believe it too. I wouldn't try to run 9s in a Fox convertible with no rollbar and no subframe connectors, but we did it with UPR's 2010 GT:
09-08-2015 11:50 AM
