5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
OEM Boss or Boss L/S Springs?
Old 03-16-2013, 06:15 PM
CoyoteGT
CoyoteGT's Avatar
Default OEM Boss or Boss L/S Springs?
Does anyone know where I can purchase OEM Boss or Boss L/S springs?
CoyoteGT is offline
Old 03-17-2013, 08:22 AM
Deranged2013
Deranged2013's Avatar
Try Tousley Ford Parts for the OEM springs.
Deranged2013 is offline
Old 03-17-2013, 06:27 PM
CoyoteGT
CoyoteGT's Avatar
thanks I'll try them out. anywhere else? I'm surprised they're not more widely available
CoyoteGT is offline
Old 03-18-2013, 08:53 AM
Deranged2013
I would start with Tousley. They are knowledgeable and the prices are good. You should also get a discount for being a forum member.
Old 03-18-2013, 09:58 PM
CoyoteGT
CoyoteGT's Avatar
Tousley Ford helped me right away and sent me this note:
"Hello, you'd be looking at $18.88 ea for the fronts, $18.13 ea for the rear, plus shipping. P/N CR3Z-5310-B & CR3Z-5560-B."
I've decided to go with BMR for a lower drop, but WOW are these prices cheap for OEM springs! Just wanted to pass this info along to you guys for anyone looking for an OEM spring upgrade
CoyoteGT is offline
Old 03-19-2013, 08:57 AM
Deranged2013
If you're going that low you may want to research and get struts and shocks. You will also need caster camber plates or camber bolts.
If you don't, you will eventually have uneven tire wear and maybe even blow out your stock struts.
Jason @ Hypermotive Performance can help you out with that.
Old 03-19-2013, 09:13 PM
CoyoteGT
CoyoteGT's Avatar
Thanks for the advice. I'm planning on Koni sport dampers, eibach camber bolts, and GT500 upper strut mounts.
CoyoteGT is offline
winner99
10-01-2015 10:52 AM
UrS4
09-30-2015 10:13 AM
mungodrums
09-28-2015 10:54 PM
Quick Reply: OEM Boss or Boss L/S Springs?
