Changing Transmission Fluid
DD. I would not put anything that light in the transmission unless you plan on paying for the replacement. Ford spec is for a heavy weight (i don't recall the exact number, cant find it) fluid.
Just throwing this out there, if you haven't done it before wear clothes you don't care about. It is the most vile smelling stuff I've ever encountered. It's how I imagine broken dreams and lost hopes would smell if bottled. Just saying...you don't want to get it on something you plan to keep.
Oem fluids are bare necessity and leave alot to be improved upon! I use amsoil signiture series 5-20 motor oil and i use amsoil extreme pressure 75-140 diff oil with amsoil friction modifier in my rear diff! The **** works great!
