blinking check engine light after redline
Was getting on my pony the other day and redlined it in 3rd and those of you who know the rev limiter kicked in..2 seconds after that the check engine light started blinking for about 15-20 seconds after then turned off. Was thinking it is normal because I read the rev limiter cuts off fuel but not sure.
Its my understanding that the rev limiter cuts spark and injectors, the computer likely read this as a Random multiple misfire.
It almost surely stored the event in the history of the computer. Go have the codes pulled and see what dtc is there.
I would almost bet it was a RMM due to the rev limiter. Really if it was any thing serious , the cel would continue to blink until either repaired or cleared.
i hit 3 in redline didnt mis a shift.....just drove it about 12 hours after i hit the rev limiter and now the check engine light is always on...just dropped it off at the dealership have to wait until tommorow morning to see what they say hopefully its not bad
I had this issue for a while
Ford eventually replaced crank position sensor after i complained about it having happened about 3-4 times and it has not happened since.
and no, the check engine light is not supposed to flash after hitting the limiter.
When mine flashed and i gave it a bit of throttle, it ran rough and weird, the actual code was "multiple cylinder misfire" when the check engine light stayed on once. After the light goes off the engine went back to normal and it only happened about once or twice a month. A ford "software update" didnt fix it. A bama tune didnt fix it. The new crank position sensor does seem to have fixed it, it hasnt come on for about 2 weeks.
After reading your newest 2 posts, you may have a different issue than me. Whatever your issue is should be covered under warranty though.
Blinking CEL is an indicator of a serious misfire which would happen if you buried the pedal and let the computer sort things out for you.
Did you stay on the gas after upshifting or did you simply let off the throttle?
