5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Wheel hop and traction issues
Old 02-04-2014, 04:55 PM
BlueThunder88
BlueThunder88's Avatar
Default Wheel hop and traction issues
Been having some nasty wheel hop and traction problems off the line. I tried higher quality and fatter nitto tires on the back but still no fix. Would lower control arms and springs eliminate the problem?
BlueThunder88 is offline
Old 02-04-2014, 05:16 PM
ModBargains
Former Sponsor
ModBargains's Avatar
Upper trailing arm and lower control arms will help. I had the same issue and I added these two things, and the wheel hop was completely removed, entirely. Here's what I use on my car:
Hotchkis Sport Suspension Adjustable Upper Trailing Arms 2011-13 Mustang
Hotchkis Sport Suspension Lower Trailing Arms Mustang
I've got other options other than Hotchkis of course, but this is what I use on my own 2013 GT.
ModBargains is offline
Old 02-04-2014, 06:08 PM
Andy13186
Andy13186's Avatar
dampers and springs eliminated mine, in 99% of road/weather conditions atleast
Andy13186 is offline
Old 02-04-2014, 06:13 PM
ModBargains
Former Sponsor
Watch this video, trust me, you want an upper trailing arm to go along with it, that's where the problem is. With new springs and dampers, you're basically using western medicine and controlling the symptoms but not controlling or ending the actual source of the problem. Check this video out, you'll see exactly what I'm talking about:
Skip to about one minute in to see the action start, you'll see what's going on.
Old 02-04-2014, 08:46 PM
Lethaldosage423
Lethaldosage423's Avatar
[QUOTE=ModBargains;8345051]Watch this video, trust me, you want an upper trailing arm to go along with it, that's where the problem is. With new springs and dampers, you're basically using western medicine and controlling the symptoms but not controlling or ending the actual source of the problem. Check this video out, you'll see exactly what I'm talking about:
QUOTE]
Damn, Thats Crazy hop.
Got any videos with the upgraded one installed to compare?
Lethaldosage423 is offline
Old 02-05-2014, 10:02 AM
ModBargains
Former Sponsor
[quote=Lethaldosage423;8345111]
QUOTE]
I do actually. This one uses a BMR product, but of course all the ones you can find on the market will work similarly well for the most part.
Old 02-05-2014, 10:15 AM
tj@steeda's Avatar
Here is a video that we put together as well:
Best Regards,
TJ
tj@steeda is offline
Old 02-06-2014, 05:17 PM
BlueThunder88
Awesome info guys! Thanks!
Just to be clear, an upper trailing arm is the same thing as an upper control arm?
Old 02-06-2014, 05:18 PM
ModBargains
Former Sponsor
Both terms get tossed around, but yes they are all talking about the same piece
Old 02-06-2014, 07:30 PM
sweger
sweger's Avatar
Very good info in this thread, as well as good videos to back it up
sweger is offline
Quick Reply: Wheel hop and traction issues
