1st oil change
#21
5w-50 shears rather quickly, especially the sub par motorcraft. I wouldn't use it as well. On SVT Performance we have a thread going where everyone shares their oil analysis reports and 5w-50 has proven to not be a very good choice.
#22
I hardly doubt you have anything to share other than a condescending attitude. The minute you posted you changed your oil at 600 miles my mind was made up. As well as many others.
#23
You (and people on other forums) look at this stuff in a vacuum; you see the viscosity dropping and assume that's a bad thing. The engine is a system, all of the parts (including fluids) have to work together.
#24
Do you think they were aware of all the problems with the MT82 before they released it? Do you think Ford makes mistakes?
And you're way off base in your thinking of the way view it. With careful thought and oil analysis tests I came to the conclusion Amsoil 10W-30 was what would work best for me.
#25
OTOH, the Track Pack originally came with the same 5w-20 as the standard 5.0, but the Boss 302 used 5w-50 and the Track Pack followed suit in MY13. So they saw some need to change to 5w-50.
#26
#27
I wasn't trying to start this huge argument I was stating why I went with a different weight and brand. As for my justifications, it might have not heated up faster (seems to as my car is garage kept and now before I get off base I get in the normal range as before with 5w-50 it would take another 2 miles obff base to get there), why I went with a 30 weight is I don't track the car (if someone could actually legitimately justify the need to run a non shearing 50 weight I will go back, unfortunately I fell it is a marketing gimic like the air vent filter), lastly it was my understanding that you don't want unecessary oil pressure. I am still learning all about cars and motors how they behave so I will keep my mouth shut as I have very little knowledge here.
Not meant to have a flame war, just trying to post stuff that might help someone out! Since the switch, way less noise coming from the engine bay area!
#28
Scotmach, when I posted that comment, it definitely was not directed at you. It was directed at JZ78817.
I actually agree with your comments, along with Slowbra302.
Forums are designed for sharing information and ideas, but lots of people enjoy trolling forums with the intent to disrupt intelligent facts and ideas. Too bad for that, because those folks will never learn anything constructive from more experienced people.
#29
Because this thread is branching off into space, I am done saying what needs to be said. Don't change you oil, it bothers me not.
#30
