Dragging a 2013 GT
Dragging a 2013 GT
How serviceable is the stock drivetrain (clutch, driveshaft, axles, gears) for a fairly steady diet of drag racing? At some point it will all be replaced with heavy duty components but I don't really want to wait. I'm already getting the rear suspension in order, welded tubes, UCA, LCA's, Panhard & Brace, LCA lowering brackets, shocks. It's a manual so I want to run a 10" wide slick. Will the stock stuff hold up or will I be scattering parts everywhere?
I have a 2013 GT as well, so I can kind of answer your questions. From what I have seen if you are 100% stock you can run all day with a low chance of breaking anything. Since you are adding slicks those add a lot more wear on the clutch, tranny, gears, driveshaft, etc... so I wouldn't do too many passes without upgrading.
You could do the lazy man's way and upgrade as you can, and fix stuff when it breaks.
If you had any power-adders I would upgrade your parts sooner than later.
It seems like you have the rear suspension mostly sorted out, so that should help when it is all installed, but it will also cause more damage to the clutch because the torque involved with sticky tires.
But... Don't take my word for it. I am basically repeating what I have read, and used my version of logic for the rest.
Hope that helps a little!
Over 100 passes on slicks and a mild Procal tune. Full option load 2012 MT-82 car on 3.73, 11 sec 1/4s. 4500-6000 rpm clutch drop launches. Nothing broke. Sway bar end links got noisy recently and a shock started to seep a little. Ford replaced both under warranty. Neither issue could be specifically tied to DR.
I'm going to stud the differential bearing caps and install a girdle type differential cover for a little cheap insurance. Other than that, I'm going to let her rip. Clutch, driveshaft and axles will have to wait until next year.
Big thing on the stock cars is, in my view, leave off the relo brackets if you're going slick. If you can't weld them in and weld the axle tubes while you're at it, you're asking to twist the tubes and trash the rear.
I'm using just a Roush upper and cheapo $100 UMI poly LCAs and that's all been fine. Stock BBP springs, shocks and bar. It's no ultimate drag setup but, I DD the car so, it has to be quiet and effective.
