Clunk (noise) when shifting gears
#41
Same issue with my 2014 gt manual
Thunk clunk no matter how smooth I try to be... 1st through 4th gears both up and downshifting... very upsetting and been there since I got the car brand new. Dealerships say it's normal, one even said " that's because you have a true muscle car"....... rubbish. Ford should be ashamed as the drivetrain is fantastic otherwise..
so sick of it I'm trading it in for '17 automatic!... with only 15k on the odometer! goodbye fun manual, but hello smoothness. Still sad though
#42
#43
What causes this clunk noise? I bought a used mt82 from https://reman-transmission.com/trans...des/?code=MT82 a few months back and it has just started to clunk bad. Only has 80k total miles on it..
#44
Reduce clunck use perfect shift timing without backlash keeping positive forward load on the drivetrain. Sooner or later one will get the clunck because of the carrier bearing with the driveshaft design. Higher RPM shifts around 3500 will help coverup slight miss timing shifts. Another complaint is early failure of rear swaybar links making clunck noise. I put an aluminum drive shaft from Shaftmasters and eliminated 90% of the clunck even with poor timed shifts. The stock shaft is heavy and the aluminum shaft has way better Ujoints.
