5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Texas Inspection
Old 02-28-2016, 02:07 PM
Grey5.0
Grey5.0's Avatar
Default Texas Inspection
New Guy here and was wondering if our tunes that have the cats deleted will pass inspection. I'm in Tarrant county. I had to have my exhaust welded so my only other option would be to weld some pipes in on my cats.I hated having to weld it but it was the only option at the time. Thanks for any input.
Grey5.0 is offline
Old 03-02-2016, 11:42 PM
txcharlie
txcharlie's Avatar
They do a OBD2 port check in Tarrant County, so it will depend on 3 things for you to pass: 1) If your tuner set the O2s/Cats to read "NA". 2) If the inspector is looking at the NA description of just looking for "not ready" conditions and 3) If they do a visual inspection of the cats. I would not go to a place that has oil change pits. It makes it too easy to do the visual. If they have to crawl on the ground or put it on a lift to do the visual, they probably won't do the visual check.
txcharlie is offline
Old 03-03-2016, 06:47 AM
Grey5.0
Grey5.0's Avatar
What should the tuner put in the tune for it to pass?
Grey5.0 is offline
Mrbobcat
05-19-2016 07:21 AM
Mead Whippo
02-24-2016 11:48 AM
MacSerio
02-23-2016 02:53 PM
AMAlexLazarus
AmericanMuscle.com
02-23-2016 10:23 AM
Rory Fraser
02-20-2016 10:32 PM
Quick Reply: Texas Inspection
