5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
2013 Boss 302 Wont Start, Fuel Pump Not Priming.
Old 04-26-2017, 05:01 PM
helikon06
helikon06's Avatar
Default 2013 Boss 302 Wont Start, Fuel Pump Not Priming.
Hello all, hoping to get some help on this. Afraid i, not sure whats up.
Drove the car home from work, pulled into the drive way. Turned the car off, came back out after aprox 10 min, cranks wont fire.
I tried the key on and off to see if it was the fuel pump switch, didnt work.
Checked power going to fuel pump control module, have power to the plug. Check for power at fuel pump plug, no power with key on. Does this mean the control module is bad?
Usually when i turn the key i can hear the fuel pump prime for a second or two, i dont hear anything anymore.
Any tips on what i should check?
helikon06 is offline
Old 05-20-2017, 08:56 AM
BigDinTexas
BigDinTexas's Avatar
Have you checked to see if the fuse is good?
BigDinTexas is offline
