5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Brake caliper crunching noise
Old 03-15-2018, 02:36 PM
putsjunior
putsjunior's Avatar
Default Brake caliper crunching noise
anytime I push the brake pedal, the driver side caliper makes a crunching noise. Even when the car is off sitting in my garage. Changed pads, rotors, and pins. Greased everything. Any ideas? I’ve been looking for an excuse to upgrade. Maybe this is it.
putsjunior is offline
Old 03-15-2018, 03:06 PM
08'MustangDude
Banned
08'MustangDude's Avatar
I get something like that from the passenger side, when coming to a stop. The place
I got the car from, replaced the driver side lower control arm, and ball joint for
"excessive play", and like idiots, didn't do the passenger side. You never, EVER replace
that stuff in singles, you always do both sides. So, I would guess the passenger side
one does have some play, because I can hear that noise coming to a stop. Doesn't do
it when at idle and I press the brake, only when coming to a stop. So, I am gonna have
to replace that side MYSELF... They did the work prior to sale, for inspection...
I had an HHR, it only needed the passenger side lower control arm, but I did BOTH
sides, because that's what you should do. Dealers should know better...
STILL waiting for the proper gauge cluster, they finally called, so I can make an appointment
to get that done.
08'MustangDude is offline
travis5049
S197 Shelby Section
10-12-2009 07:13 AM
KMatch
05-11-2009 03:10 PM
stocksixer88
04-09-2008 09:57 AM
oshkoshbajawsh
11-15-2007 03:17 PM
Supernaut
08-20-2007 10:26 AM
Quick Reply: Brake caliper crunching noise
