5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Fuel Injectors for E85
Old 01-23-2018, 12:07 PM
ewmohr
ewmohr's Avatar
Default Fuel Injectors for E85
I am considering installing some Ford Performance 47lb injectors so I can run E-85 in my 2012 GT Auto. Looking for pros and cons. I already have an SCT tuner and a Steeda Cold Air Intake. Hoping to shave a tenth or two off my quarter mile time. Do I need a boost-a-pump? Do I need anything else? Should I just save my money?
ewmohr is offline
Old 01-24-2018, 07:17 AM
Buck Sergeant
Buck Sergeant's Avatar
While the stoichiometric (chemically ideal) air/fuel mixture ratio for gasoline is approximately 14.7:1, with ethanol it is around 9.79:1. In carbureted applications you will usually need higher-flowing metering blocks calibrated for E85, while in fuel-injected applications you may need to upgrade the injectors to a greater lb/hr rating. In all cases, Ksiazkiewsicz notes, “You need to look over your entire fuel delivery system, including the pump and lines, to ensure it can deliver the additional fuel mass.” And while you’re there, here is another issue to consider: materials compatibility. Ethanol can be downright unfriendly to some traditional fuel-system materials-cork, for example. On late-model cars it’s not a big problem since they are already designed for fuel blends up to E20 (20 percent ethanol). But on older cars in particular, gaskets, seals, and hoses will need to be updated to ethanol-compatible materials, as in the long term the exposure will shorten their service lives. Also, aluminum fuel lines must be fabricated from standard anodized tubing. Naked aluminum corrodes when exposed to ethanol. However, ethanol presents no hazard whatsoever to oxygen sensors and catalytic converters-a definite plus.
Buck Sergeant is offline
Old 01-24-2018, 07:54 AM
proeagles
proeagles's Avatar
Save your money.
proeagles is offline
GT John
02-02-2021 02:29 AM
Boostaddict
Lethal Performance
10-02-2012 09:34 AM
Cobra Drifter
03-31-2011 01:22 PM
NeoTokyo
01-09-2011 07:46 PM
Monch
08-13-2004 03:26 AM
Quick Reply: Fuel Injectors for E85
