shocks/springs??
shocks/springs??
Hi guys,I have a 2014 gt/cs convertible which has been lowered approx 1 3/4 " in the rear and 1 " in the front . Also did wheels and tires at the same time , keep the 19" height but put 9" wide on the back and front and wider tires .
I put the springs in within the 1st few weeks of getting the car so didnt drive it much with the stock springs in it .
I notice that when I go around any sweeping corners where the road is a little uneven the rear of the car seems to bounce /jump sideways a little bit in the rear ?
Is there an inherent issue being a convertible or should i look deeper into say the shocks etc.
I also bought an adjustable pan hard bar to install.(not done yet)
Any ideas guys , the car is mainly a cruiser so wont see much time on the track.
Cheers guys
Cheers guys
Shocks/springs
Hi Jim,
Thanks for your reply mate , I will check that the shop that installed the springs did this.
Is there any particular height they should be Jim ?
If I trim them a bit more is there any other issues that that could cause?
Cheers buddy,
KP
Cheers buddy,
KP
