covette trouble
Just to clarify the ZR1 is NOT the big block, it is the 6.2 liter Supercharged LS9.. The Z06 is the 7.0 (427) LS7 motor...
Back to the matter at hand why would a C6 want to play with a 6cyc stang.. Does he just want an easy kill... I can't get one of these cars to run me at all... I wonder by the numbers if I can kill one
The LS7 is based on the Gen IV architecture of the current LS motors, which are all small blocks. The physical exterior dimensions of the engines determine if it's a big block or a small block, not displacement. LS7 has the same exterior dimensions as the LS3, LS-A, LS2, etc.
[QUOTE=Deki;7994388]The LS7 is based on the Gen IV architecture of the current LS motors, which are all small blocks. The physical exterior dimensions of the engines determine if it's a big block or a small block, not displacement. LS7 has the same exterior dimensions as the LS3, LS-A, LS2, etc.[/QUOTE
TOUCHE ....The geezers that drive those vettes consider the Z06 the big block car. regardless they make hood plates that show the 427 Logo like the days long past. Interior or exterior measurements aside
