MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   Audio/Visual Electronics (https://mustangforums.com/forum/audio-visual-electronics-28/)
-   -   What's the difference? (https://mustangforums.com/forum/audio-visual-electronics/103260-whats-the-difference.html)
stangman2354 Mar 9, 2006 03:18 PM
What's the main difference in a mono amp and 2 channel amps? Which one would be better for 2 subs?
1fastzook Mar 9, 2006 03:31 PM
RE: What's the difference?
a mono amp only has one chanel.It all depends on what ohm your subs are and what ohm load the amp is so i cant tell you what one would be better for 2 subs.Mono amps usually are not as clean as 2ch amps but usually the draw less power.2ch amps have a better low note and better sq
stangman2354 Mar 9, 2006 05:17 PM
I have the Kicker Comp VR 05CVR124 12" Dual 4-Ohm Voice Coil Component Sub 12" Component Subwoofers
So I guess thats 4 ohms per sub and I have 2 of them.
The amps I was looknig to power these was the Kenwood KAC-9152D Subwoofer Mono Amp....would be good or what should I get?
1fastzook Mar 9, 2006 05:34 PM
Im pretty sure the kenwood amp will only handle a 2 ohm load so that wouldnt be good unless you run one amp per sub or just one sub.You can wire each of your subs 2 or 4 ohm.So if you want to run both subs you would have to get a 1 ohm mono amp or a 2 ohm stereo 2ch or a 1 ohm mono 2ch.if you cant figure out what im talking about just list some models of amps and i will help you out on witch one to get
stangman2354 Mar 9, 2006 05:38 PM
well what brands of amps would u reccomend for the price and quality?
1fastzook Mar 9, 2006 05:48 PM
it all depends what your price limit is.tell me how much you want to spend for a amp.I can get you a jbl crown for only $3000.00 lol
stangman2354 Mar 9, 2006 05:54 PM
lol ...umm probably 400 the most
1fastzook Mar 9, 2006 06:04 PM
you might want to look at some mtx amps they are decent for the dollar.check ebay for some used us amps,mtx,mmats,dd,jbl there are alot of good brands out there. you might just want to buy 2 smaller kenwood amps.look into it give me some model numbers and i will help you pic the best for the $
stangman2354 Mar 9, 2006 06:12 PM
2 smaller mono kenwood amps so i could hook one to each sub?
stangman2354 Mar 9, 2006 06:17 PM
and if i had a 2channel amp it would be the best for my situation? and i wouldnt need 2 mono amps?
© 2026 MH Sub I, LLC dba Internet Brands
