Amp won't turn on !!
I have 2 mtx 6000 subs, and a MTX 4250D amp. The amp won't turn on. It was working fine, this started about a week ago after 6 months of it working. I checked the power, ground, and remote lead with a voltmeter - all are powered. ANy suggestions ?
RE: Amp won't turn on !!
check the fuse on the side of the amp, if its not blown then your amp is
THIS WHAT HAPPENS WHEN YOU BUY THAT HOT **** FROM MD ..aka GA FENCE COMPANY*LOL*
Are you positve your ground is good?Ive done that before wher ive tested the ground and i twas good, then music kicks in and the amp wont play . and make sure to check the really obvious stuff like rcas before you go and buy a new amp
| All times are GMT -5. The time now is 07:09 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
