MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   Audio/Visual Electronics (https://mustangforums.com/forum/audio-visual-electronics-28/)
-   -   running multiple wires, here's a trick (https://mustangforums.com/forum/audio-visual-electronics/354678-running-multiple-wires-heres-a-trick.html)
BigFloppy Oct 7, 2007 08:12 PM
This weekend while hardwiring in my new Valentine V1, I remembereda little trick to running multiplewires (power/Gnd/more) and wanted to share this with you guys out there...
Assuming you are running 2 or more wires, get someone to hold one set of ends (I used the wide for this)
THEN, with wire held tight, put the other (your ends) into a drill and start it running, keep it taught!
The wires are going to twist together for you and make running more than 1 wire much easier especially if you're running a good length of wire
jakeachy Oct 7, 2007 08:15 PM
RE: running multiple wires, here's a trick
ORIGINAL: BigFloppy
if you like crackles,pops and road sound/vibration in your system.
MU71L4710N Oct 7, 2007 08:36 PM
well hes doing this for a radar detector. but i agree with you would not do this with audio stuff.
BigFloppy Oct 7, 2007 08:59 PM
Done this with small power stuff before and never had a problem, my XM, Sirius and iPod"Power" areboth wired this way, keeps the install nice and clean (also makes threading wires easier cause you've only got to thread the equivalent of 1 wire, not 2. Also powered the wife's auto-dimmng mirror this way without any issues
NO, I wouldn't even think about putting audio cables this way
ttocs Oct 7, 2007 09:17 PM
my whole system is done with this, and there is alot of it. We call it airline wrapping in the industry. It is the 1rst part in prepping an alarm.
So with this being said you do not want to do this with the rca cables. IT IS OK TO RUN THE REMOTE TURN ON WITH THE RCA CABLES, but it does not need to be twisted around it this will not cause noise but try to keep the rca's away from factory power wires and motors.
© 2026 MH Sub I, LLC dba Internet Brands
