MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   Audio/Visual Electronics (https://mustangforums.com/forum/audio-visual-electronics-28/)
-   -   MTX 15" CVR's (https://mustangforums.com/forum/audio-visual-electronics/411447-mtx-15-cvrs.html)
85stang1373 Feb 25, 2008 07:38 PM
MTX 15" CVR's
Are they good? Are they loud? And also what would i all need to run these in my mustang? (If anyone can tell me what the whole setup could be would be apperciated) ((like HU, amp, capacitors all the the little odds and ends))
thanks so much
oh and i could get the speakers in a box for 200$
85stang1373 Feb 25, 2008 08:16 PM
RE: MTX 15" CVR's
IM AN IDIOT!!! i put mtx instead of kicker!
So are replace mtx with kicker and then try to answer the question s if ya can.
thanks alot!
seight311 Feb 25, 2008 08:26 PM
RE: MTX 15" CVR's
Your answering your own question... sorta.
A decent enclosure to have someone build it for you should cost around $200 alone.
85stang1373 Feb 25, 2008 08:28 PM
RE: MTX 15" CVR's
so i should get em?
apolnerow08 Feb 25, 2008 08:28 PM
RE: MTX 15" CVR's
Are you sure its a MTX CVR or do you mean a Kicker Comp-VR aka CVR...The MTX 15" is 600w @ 4ohms rms so Id suggest a JL A1800 mono amp, 640w @ 4ohms rms. If you wanted to save money and go off brand, not undermining their quality, check out MA Audio's HK2000D. Its got 750w @ 4ohm rms, more than plenty to power the MTX CVR. Elemental Designs has an amp, NINe.2x two channel but bridged and you can get 600w @ 4ohm rms..just enough to power the MTX. With that amp I might suggest a capacitor to prevent headlight/dashboard dimming. As far as headunits, get a new one rather than keeping it factory. Better sound quality out of your exsisting speakers and also more manual settings for your subs and what not to shape the sound you want. Aftermarket HU's have preamp outs too so you can run RCA's to your amp for clear sound.
apolnerow08 Feb 25, 2008 08:30 PM
RE: MTX 15" CVR's
Wow disreguard my previous post then..
85stang1373 Feb 25, 2008 08:39 PM
RE: MTX 15" CVR's
i didnt even see your post because you posted like 20 seconds before i did so sorry
thanks for the input so far !
apolnerow08 Feb 25, 2008 08:47 PM
RE: MTX 15" CVR's
Well then id suggest the eD amp I said before minus the cap.
85stang1373 Feb 25, 2008 09:00 PM
RE: MTX 15" CVR's
the the elemental designs amp without the capacitor?
apolnerow08 Feb 25, 2008 09:27 PM
RE: MTX 15" CVR's
Yea, its about 100watts rms more than you need but you can lower the gain on the amp so you dont put too much power to the sub. Also, caps really arent needed. They add a nice touch of neon sometimes, depending on what you like, help reduce dimming, and also kinda clear out the signal but chances are you wouldnt notice the difference in sound quality with or without one.
© 2026 MH Sub I, LLC dba Internet Brands
