MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   Audio/Visual Electronics (https://mustangforums.com/forum/audio-visual-electronics-28/)
-   -   Will Mach system play CD-R's? (https://mustangforums.com/forum/audio-visual-electronics/46558-will-mach-system-play-cd-rs.html)
GreyStang May 7, 2005 07:32 PM
I burned a CD-R of my favorite tunes and tried playing it in my Mach 6-pack headunit, but it wouldn't accept the CD.. says something about a disk error...
Can the Mach 6-CD deck play CD-R's? Anyone have any luck with that?
GT_dOc May 8, 2005 12:15 AM
RE: Will Mach system play CD-R's?
Should let you. hmmmm. I have the Mach 6-CD, it lets me use em.[&:]
GreyStang May 8, 2005 03:01 PM
OK well that's good to know. One thing I noticed the CD-R blank I tried to use is a bit thicker than a storebought music CD,, and maybe the player is just not liking it because it is too thick?
I'm using no-name generic cheapo CD-R's,, what type did you use, any particuar brand? I'll go grab some if they'll work.
dan May 8, 2005 03:27 PM
i use the Fujifilm 80 minute Cd-R's i get at comp usa, cheap, and they work. If it still doesn't work try using a CD-RW. My Xbox wont accept CD-R's but it will accept CD-RW's
OH yea and make sure you can play the CD on like a home sterio to make sure its not just the burner or an error, etc.
GreyStang May 8, 2005 10:12 PM
OK I took my cheapie noname CD-R & it played in my home sterio no problem. One thing I noticed with it in the car, it seems the CD didn't even get fully sucked into the head unit (the cd slot never closed after loading it) that was why I wondered if the "thicker" CD-R just wasn't fitting in.. so scrap those CD's
I tried burning a Sony CD-Rw with the same stuff. That disk would NOT play in my home sterio, it says "bad disc" I guess the home system wasn't built to handle CD-Rw's. I tried it in the car anyway, and THAT CD did get fully loaded into the head unit. But after trying to play it a few times it finally complained about "bad disc" too.. dam!
I will go find some of those 80 minute Fujifilm CD-R's & give that a shot. Thanks for your help.
dan May 8, 2005 11:09 PM
yea it sounds like the thickness. My dad's ford explorer has the same 6disk changer that we have, and he put in a cd that had a cover on it and it got jammed up and we had to take it apart. All because the paper cover added a little more thickness i guess.
GT_dOc May 10, 2005 01:10 AM
That must be it because it happend to my brother once before when he had his mustang I just remembered and I think we figured out it was the thickness (cheap CD-R lol).
GreyStang May 10, 2005 06:24 PM
OK I grabbed some 80min Fujifilm CD-R's, burned on some tunes, and it WORKED in my car! Coooooooll!!!
Thanks for the tips guys! Now, is it just as easy to get my 6-pack Mach headunit to play MP-3's? LOL
N E way, I'm groovin again! [8D]
© 2026 MH Sub I, LLC dba Internet Brands
