What amp to use with Plok DB1240 sub???
What amp to use with Polk DB1240 sub???
Ok i bought a New Polk Audio DB1240DVC sub
http://www.polkaudio.com/images/car/...ack/db1240.jpg
Specs:
Electrical
Overall Frequency Response 27-200 Hz
Nominal Impedance 4 ohms
Power Handling (continuous) 360 w
Power Handling (peak) 720 w
Efficiency 88 dB
Voice Coil Diameter: Driver 2" (5.08cm)
Driver Mounting Depth
Top Mount 6" (15.24cm)
Bottom Mount 6-3/4" (17.14cm)
Cut-out
Driver Cut-out Diameter 9-1/16" (23.02cm)
Thiele/Small Parameters
Recommended Enclosure Sealed/Ported/Bandpass
Resonant Frequency 28.3 Hz
Qms 11.7
Qes .4
Qts .4
Vas 2.87 cubic ft/81.4 L
Cms 215.5 Micro Meters
Bl 14.5 Tesla Meters
Sd 80.6 sq in/520 sq cm
Xmax (linear) .62 inch/16 mm (peak to peak)
Mms 146.7 g
And i wonder which amp would be best to use. Im building my own box, I got rid of my kickers cause they required to much air space. This sub only needs 1.5 cubic foot box so i can get it in the trunk. These are the amps im lookin at.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=360141505403
http://cgi.ebay.com/PIONEER-GM-D7400...3A1%7C294%3A50
http://cgi.ebay.com/MTX-TC4001-Car-A...3A1%7C294%3A50
http://cgi.ebay.com/MTX-X-Thunder-30...3A1%7C294%3A50
Specs:
Electrical
Efficiency 88 dB
Cut-out
Qms 11.7
Qes .4
Qts .4
Mms 146.7 g
a class D mono-sub amp is more efficient for this application. If you get one that is 2 ohm-mono stable you will be able to get max power out of your amp. I don't pay attention to power ratings on speakers myself, just match the impedence and give it as much clean power as you can. The budget will probably help decide which brand you can go with and the brand can make all the difference.
I have not posted anywhere else lol. I dont want to over power the sub though and blow it. So i was wondering will that MTX 300w @ 2 Ohm be good since its a DVC which would make it 360 w RMS at 2 ohms max on this sub.
Does anyone know if Polk Audio are good. I just wanted something different and away from Kicker and MTX subs. Cause everyone has one.
What type of box are you putting the sub in?
If in ported you should spend the extra money on the amp to get something higher quality with a subsonic filter. Woofers in ported enclosures do not like playing notes below the tuning frequency at high volumes...
You cannot beat this for the money...
http://ikesound.com/profile_ha700m
breaking
10-02-2015 01:27 PM
