Replacement bass audio
Hey, I need some help finding some new speakers. My 2003 Stang has the Mach 460 audio system but has pretty much no bass at all, so I'm considering pretty much scrapping it and replacing all the speakers. I'm thinking of having the rear two speakers and the lower two door speakers pretty much pure bass and the upper two door speakers normal. Does anyone know what some of the best speakers are? Like 100 to 175 bucks total though, I'm pretty poor. I honestly have no clue what any of this means other than "bass" and "tweeters" so anything helps, even if it's just tips on what to look for.
Bass in the doors does no good without an enclosure like the Shaker systems have in the
S197 Mustangs. Your best bet is to upgrade your speakers, and add a subwoofer to the system. Good rear deck speakers will produce bass, but the trunk is the enclosure, so the speakers have to be good. Sub Bass is 20 to 60 Hz, this is where bass drums are, and sub bass means subwoofer. Bass that is produced in this range is felt more than it is heard, providing a sense of power. It moves air.. Bass is 60 to 250 Hz. The fundamental notes of rhythm are centered on this area. Too much boost in the sub-bass range can make the sound overly powerful, whereas too much cut will weaken and thin out the sound. Some bass drums, like from Metallica's "And Justice for All" album, extend into this range. Those two areas are what causes a lot of speaker movement, and cause the most damage to the inner ear. Pure bass is speculative, because bass covers more than bass drum. You can't have PURE bass in an audio system, because you aren't listening to just bass. I know what you meant, but just be clear on your words. You want signal separation based on the speaker, not purity. If you have open back subwoofers in the door, with the other speakers, contaminates the bass sound through the actual cone material. That is why you have to enclose subwoofers. If you were to turn your open back subwoofers in the door off, and just have the other door speakers on, you can still hear sound through the subwoofer, it resonates out of its cone, passive resonating. Thus, you do not have a purified bass signal with other frequencies from the other door speaker resonating out of it. Low Midrange: 250 to 500 Hz, contains the low order harmonics of most instruments and is generally viewed as the bass presence range. Boosting a signal around 300 Hz adds clarity to the bass and lower-stringed instruments. Too much boost around 500 Hz can make higher frequency instruments sound muffled. The frequencies above 500Hz-2Khz are midrange and those above, so not covering that... You must enclose your subs for clean sound. |
(Post 8647309)
bass in an audio system, because you aren't listening to just bass. I know what you meant, but just be clear on your words. You want signal separation based on the speaker, not purity. |
