MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   Audio/Visual Electronics (https://mustangforums.com/forum/audio-visual-electronics-28/)
-   -   Cdwon't eject, what to do? (https://mustangforums.com/forum/audio-visual-electronics/81114-cdwont-eject-what-to-do.html)
prozac Dec 13, 2005 11:43 PM
Ok well the cd won't eject from my girlfriends head unit, what do i do?
thanks
Zach
pj1010 Dec 13, 2005 11:47 PM
RE: Cdwon't eject, what to do?
Should be able to remove the metal housing and get it out. What exactly is it doing?
prozac Dec 13, 2005 11:51 PM
it is doing everything perfect, except when you try to eject the cd, it sounds like it is ejecting and doesn't
p0rsche23 Dec 14, 2005 08:31 PM
lol mine is gay like tha too,sometimes it just pops its head out,sometimes not,i just keep hitting eject and moving my a/m head unit up and down until it can come out or i can pull it out? lol
get what ya pay for i guess----circuit city free install over 100 head unit purchase! fuk them
seight311 Dec 15, 2005 02:47 AM
Well mine was doing the same, basically what it is is that the cd player chassis is out of alignment. not much you can do about it but have it sent to a service department. it will cost you about $75 to have them realign it or almost 4 times as much if they need to replace it. Unless this is a top of the line unit, which if you bought it from CC I can certainly say it's not. Just buy a new one. And this time go to a better retailer and when they mention the extended warranty consider it this time. That is of course if you purchase a unit over $250, anything bought for less than that i see no reason to assume it would function problem free for more than 2 years.
DirtyGt Dec 15, 2005 02:49 AM
if it's the 6 disk Mach changer i had the same problem and i fixed it myself. it happens a lot actually.... is it the changer?
ironh19 Dec 17, 2005 12:29 PM
My cd player was doing the exact thing so I tore it out and bought one from ebay to replace it and it turns out that had the same problem, so I threw both out and installed an aftermarket player, haven't had a problem since and my sound system sounds so much better.
Birdieman4 Dec 17, 2005 04:45 PM
Yes, the 6 cd Mach unit is known to stick. It seems to do it when it's hotter. On mine, when it sticks, I insert a little knife blade on lightly press down on the top of the stuck cd. It usually spits it out. But if you wait too long, you'll get a 'cd error' message, and then you'll have to try to pull it out, manually. A skinny pair of tweezers will accomplish this. When I fist bought my 01, Ford put 3 new units in to no avail. After the final swap it was better. But it still occurs from time to time. Ever notice how hot the ejected cd's can be? My theory is the heat slightly warps the plastic, and causes the tolerances to diminish, in turn causing sticking issues.
mustangman02232 Dec 17, 2005 06:42 PM
i just have a blank CD that i use to slip in over the other one, will it open the door or does it just say CD error?
© 2026 MH Sub I, LLC dba Internet Brands
