wiring harness for mach 460?
im tryin to replace the factory radio/cd player for the mach 460 with a new kenwood headunit. i cant find a wiring harness that will fit the mach system. does anyone know where to find one?
RE: wiring harness for mach 460?
http://www.crutchfield.com/S-ZIGpf2e...51&I=142C4FDK5
I can't say for sure, but I thin this one will work. Don't hold me to that.
ORIGINAL: tony28
yea ive looked at that one before. according to the reviews its fits but one guy said it was crap.
The only other option I see at this point is to buy some RCA wires, cut them and plug them into your aftermarket head unit. Then run the cut RCA wires into the factory amplifiers.
http://www.amazon.com/gp/product/B00...27957?n=172282
If you cut one end off of this wire, you will be left with essentially a two conductor wire (positive and negative for one speaker). You will need 2 of these.
To make this even easier, buy the harness I showed you, cut that leve adjustor off and connect the cut site of the RCA's to the harness. This will make it easier to discern which speaker/lead you are plugging into.
This should work, in theory.
Try this, it is for 00-04, but it may work on yours. Or look at the others he has to see if he has one for your car,
http://cgi.ebay.com/ws/eBayISAPI.dll...RK%3AMEWA%3AIT
