amp won't work
i got mtx amp and i hooked it up but no sound the light comes on but no bump. it's a class d mono. any help would be apreciated.
RE: amp won't work
I'm afraid more detail will be needed to answer your question.
RE: amp won't work
Check all connections and fuses...
RE: amp won't work
ORIGINAL: baddog671 Check all connections and fuses... |
RE: amp won't work
what color is the light?
RE: amp won't work
did you forget to hook up your remote wire or cehck to see if any wires came loose.
RE: amp won't work
if it is used the pre amp is burnt if its new check connections che rca cables and every thing even if they r new
RE: amp won't work
ORIGINAL: 89vert86top if it is used the pre amp is burnt if its new check connections che rca cables and every thing even if they r new |
RE: amp won't work
i have always had a system and 1 time i bought a used amp hooked it up everything came on light and all but no sound i tryed everything even bought and ran all new wires and still nothing took it to a shop and the pre amp was burnt so its just a likely instance
RE: amp won't work
so if the pre amp is burnt out is it trash? the light was green i was running a cap uh i don't know what else you need. um when i hooked up my old amp it worked .
| All times are GMT -5. The time now is 03:58 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
