Need some help on coilover conversion for my Bullitt
When you do a coil-over conversion, do you have to use caster camber plates? I'm looking at putting LT headers on my Bullitt and I figured while I had the front torn apart anyway, maybe do a K-member, control arm, coilover swap...But I'm a cheapskate and don't wanna spend more than I have to haha! Any help appreciated. THANKS!!
RE: Need some help on coilover conversion for my Bullitt
yes you will need C/C plates, you will need an allignment afterwards, you dont need to go aftermarket k member (i didnt)
look at mods in sig..
huge ride improvement espeically with adjustable shocks... the limit of the car will increase probably more then you can handle.
Thanks, I am going to install a set of long tubes on mine and figured if I gotta take it out anyway I might go ahead and get the whole package. I already did the whole swap on my '89 Notch and it wasn't too bad.
when i did mine i replaced everything upper/lower control arms tubular k tokico d-specs and cc plates, anytime you unbolt the front struts you have to get an aligment or at least you should
69MustangCoupe393cid
10-03-2015 10:33 AM
JDWalton
09-24-2015 08:47 PM
