What are you working on?
Old 07-25-2015, 06:55 PM
  #10071
Sleeper_GT
Sleeper_GT's Avatar
Here's a sound bite
Sleeper_GT is offline
Old 07-25-2015, 07:51 PM
  #10072
clowe1965
clowe1965's Avatar
Well it's been a long two weeks. Pulled the gears on the mustang trying to get rid of the whine and I had some weird vibrations going on that didn't 100% go away with the stock driveshaft. So amidst this I found that the backlash was set to .015-.017 (range is .008-.015). Set it at .011 and put it all back together. Whine got quieter but the vibration issues were still there. So canceled on MW and took it all the way apart and installed a new set of 3.73's and invented some swear words. Found the preload on the pinion bearings was at 35in lbs (16-29). Thought that might be the problem. Nope. Reinstalled everything, 28in lbs preload(that was close!) and .011 backlash, all new bearings and put the 1 piece ds back in. The whine is gone. But the rumbling/vibrations are still there. So I'll be flipping the ds 180, check it and hope for the best. If not I'll have to go see about getting it rebalanced. Just for kicks, here's the setup I ended up using to get the crush washer. Vise grip ratchet cheater, chain fall and a piece of scrap steel bolted.to the flange.
Jessie's jeep has death wobble, but I found the toe was way out of spec so hopefully that fixes it. Then onto the other jeep. I've been driving it for 2 weeks with a busted transmission and the rebuild kit in my living room so that's hopefully gonna be under the knife for this week.
clowe1965 is offline
Old 07-25-2015, 09:19 PM
  #10073
Zodiac
Zodiac's Avatar
Wow that is an incredible amount of work. Hopefully getting the DS rebalanced will fix everything. I don't envy you lol.
Zodiac is offline
Old 07-25-2015, 09:41 PM
  #10074
alan0614
alan0614's Avatar
JJ, as always....great work
Crint, hope the 180 is the fix. You have been a busy boy.
Ordered a front suspension rebuild for Lola. That's next on my agenda. Also got an electronic ignition to replace the points and condensor.
alan0614 is offline
Old 07-25-2015, 11:12 PM
  #10075
clowe1965
clowe1965's Avatar
Hoping.
Gonna do the Shelby drop alan?
Old 07-26-2015, 07:51 AM
  #10076
alan0614
alan0614's Avatar
No Clint, just staying stock.
alan0614 is offline
Old 07-26-2015, 08:11 AM
  #10077
Sleeper_GT
Sleeper_GT's Avatar
Damn Clint.......You the man
Thanks Alan
Old 07-27-2015, 08:08 PM
  #10078
alan0614
alan0614's Avatar
Check this out JJ......you need one.
https://mustangforums.com/forum/2005...ml#post8498522
alan0614 is offline
Old 07-27-2015, 08:27 PM
  #10079
Sleeper_GT
Sleeper_GT's Avatar
Oh snap!!!!!!!!!!!!!!!!!!!!! Game on!
Old 07-28-2015, 05:52 AM
  #10080
Gadgetech
Gadgetech's Avatar
Default What are you working on?
That's fricken awesome!
Gadgetech is offline
Quick Reply: What are you working on?
