Manual tranny fluid change
Old 03-05-2013, 05:52 PM
06RubyFire
06RubyFire's Avatar
Default Manual tranny fluid change
I am having trouble getting my tranny in first gear so I think its time for a fluid change. Any suggestions on what to use? Ford, amsoil, royal purple, mobile one?
06RubyFire is offline
Old 03-05-2013, 06:53 PM
FrostByte
FrostByte's Avatar
I went to RP & it has quieted tranny down but if your having shifting probs then it may be to late.
FrostByte is offline
Old 03-05-2013, 07:02 PM
06RubyFire
06RubyFire's Avatar
I hope not, I bought it with 44000 ,it now has 48000. It actually shifts good, just happens when I'm at a stoplight and then try and put it in gear.
Old 03-05-2013, 07:06 PM
alan0614
alan0614's Avatar
Doing a little googling, Amsoil gets good reviews.
alan0614 is offline
Old 03-05-2013, 07:15 PM
Jeffk
Jeffk's Avatar
Location: Thomasville, NC Where we beat headers into submission!!
I put amsoil in mine. Got it from Hypermotive! It did improve shifting some and quieted it down some. Another thing that you might want to check is the brake master to make sure it's full because that is also the clutch master.
Jeffk is offline
Old 03-05-2013, 07:23 PM
06RubyFire
06RubyFire's Avatar
Cool I will check it as soon as the monsoon blows over tomorrow. Thanks Jeff, Alan I've researched a little and was leaning toward amsoil.
Old 03-05-2013, 10:39 PM
Poppacapp
Poppacapp's Avatar
Just a thought, but when at a stoplight, try putting the car in 2nd gear first, then up to first.. see if that helps any.
Poppacapp is offline
Old 03-06-2013, 05:09 AM
06RubyFire
06RubyFire's Avatar
It has only happened twice, the first time it was hard to get in second also. I sat there so long trying to get it in gear the light turned red. It was very cold that day too. What made me mad was all of a sudden in just falls in gear without any effort. Second time I was ready for it and put it third made it roll forward a little and then it went into gear.
Old 03-06-2013, 06:40 AM
Jeffk
Jeffk's Avatar
I doubt it's the transmission, possibly the clutch/throw out bearing/slave cylinder if it's a mechanical issue and not just fluid.
Jeffk is offline
Old 03-06-2013, 03:07 PM
Poppacapp
Poppacapp's Avatar
I agree with jeff. Clutch not disengaging all the way. The way they test for bad sunchros is try to put the car in gear with pushing clutch in. Good synchro will not let it in gear and rpm will dip slightly. Bad synchro=grind. Try the synchro test and see if it does exactly what it did to you before. Not go into gear.
Quick Reply: Manual tranny fluid change
