CJ Pony Parts We carry Ford Mustang parts for every Mustang built from 1964 to present. CJ's has everything you need to restore your Mustang or make it the performance & aftermarket styling machine you always dreamed of!
Mustang BMR Rear Lower Control Arms Installation Video 2005-2014
Old 10-10-2013, 11:18 AM
Steve@CJPP
Former Sponsor
Steve@CJPP's Avatar
Default Mustang BMR Rear Lower Control Arms Installation Video 2005-2014
Mustang BMR Rear Lower Control Arm Non-Adjustable With Poly Bushings Pair 2005-2014 | CJ Pony Parts
This pair of BMR Rear Non-Adjustable Lower Control Arms with Polyurethane Bushings fit all 2005-2014 Mustangs. They replace your stock control arms, which are marginal, at best. All of BMR's control arms are TIG welded and utilize either greaseable spiral fluted polyurethane bushings or Teflon lined HD spherical bearings by QA1. Also, all rod end spacers are 304 stainless, so you won't find better quality components.
For installation, you'll first disconnect the factory brake cables and then uninstall your original control arms one at a time. Then, secure into place and torque the new BMR lower control arms, reconnect the brake cables, and tie them to the control arm it's near if you find that they hang too low. Total installation takes around one hour.
See more 2005-2014 Mustang Rear Control Arms from CJ Pony Parts:
Mustang Rear Control Arms | CJ Pony Parts
See more BMR Mustang Parts from CJ Pony Parts:
BMR Fabrication - Ford Mustang Parts - CJ Pony Parts
Steve@CJPP is offline
djbigskrilla
09-20-2022 01:04 AM
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
inyadreems
08-21-2015 09:10 AM
daytooday
08-11-2015 09:22 AM
Quick Reply: Mustang BMR Rear Lower Control Arms Installation Video 2005-2014
