'67 Fully Restored Coupe, Tampa Fl.
1967 Mustang Coupe restored from the ground up. This car is a factory a/c, 289 , C4, p/s that still has the original engine, transmission, rear axle, etc. . Yes the air actually works, unlike most that say "all parts there, just not hooked up B.S.". It is not a hotrod, a clone,.or tribute. It is however complete to factory original specs. I have won the last 2 ( the only 2 car shows entered and won for "original" concours correct car) car shows. To begin with whats new: all 4 quarters, gas tank, floor pans, front grill assembly, upper control arm bushings, lower control arm bushings and arm, upper and lower ball joints, control valve, power assist piston, all 4 brakes have new shoes, hardware, wheel cylinders, and bearings, new dash pad, COMPLETE interior, seat buns (foam), instrument cover, instrument bezels, carpet, headliner, visors, rear view mirror, courtesy lamps, vaccuum harness for climate control, oil pump, water pump, cam, crank and rod bearings, pistons, camshaft, lifters (rebuilt the original engine), heater core, evaporator core, a/c compressor, ALL a/c hoses, condensor, drier, radiator, u joints, front windshield, starter solenoid, rear bumper, rear tail light lenses and bezels, all window seals, drip rail seals, beltline seals, door seals, front and rear window seals, door hardware and panels, speaker for radio, antennea, all 4 shocks, fuel sending unit, the entire elec system is perfect, etc, etc, etc. Note the a/c compressor is a Sanden for use of R-134, I have the factory York if you wish.
As for whats rebuilt: the engine, as seen from new engine parts, cylinder heads (and resurfaced), tranmission along with new converter, p/s pump, master cylinder, carburator, distributor (new bushings, breaker plate, gear, advance, etc), front spindles, all 4 window regulators and channel guides, seat belts and retractors, radio (factory am that works perfect), style steel wheels and new tires, etc, etc, the list goes on and on.
To sum it up, NOTHING on this car hasn't been repaired or replaced by an ASE cert mechanic. I will rip out the interior to prove what's been done, for serious buyers only who have cash in hand!!!!!!!!
What it needs: horn button, rear trunk seal, windshield washer pump, trunk mats if you so wish.
Feel free to set up an appointment IF SERIOUS to inspect this car. If you aren't serious don't waste mine or your time. I am selling this car for space reasons, I have 5 cars and am having to make a heartbreaking decision. But I am not desperate, so don't bother asking if you don't have reasonble offer. That being said, it is a MUST that this car gets a good home, has too much of my blood, sweat and tears not to : ). Best to respond to my cell phone, 941-915-0051 $17500
[IMG]local://upfiles/47520/D3748BBB8AC54F0FA25E676E89CAE24B.jpg[/IMG]
[IMG]local://upfiles/47520/86CFD205FD2145FC8259E717BF1A7B74.jpg[/IMG]
[IMG]local://upfiles/47520/9442001E02DB459A8027CD4EF5A20FDA.jpg[/IMG]
[IMG]local://upfiles/47520/F746C86059FA4B7D8B167F2315E902A3.jpg[/IMG]
[IMG]local://upfiles/47520/59F8317385C745178511BF542E6ABD8D.jpg[/IMG]
RE: '67 Fully Restored Coupe, Tampa Fl.
More Pics
[IMG]local://upfiles/47520/AF427ACABC864FC58939A716C0579EB0.jpg[/IMG]
[IMG]local://upfiles/47520/0A3BFB029D46449889753C79B90D40B3.jpg[/IMG]
[IMG]local://upfiles/47520/119FE27842EF473ABF036B11CF44C2F5.jpg[/IMG]
[IMG]local://upfiles/47520/AD575F1E3276439DAE09E84C23E06F5D.jpg[/IMG]
[IMG]local://upfiles/47520/53697A10925249BA8C9D6E3F5AB23AC6.jpg[/IMG]
More Pics
[IMG]local://upfiles/47520/514322B3AF1E418CBC70331366789036.jpg[/IMG]
[IMG]local://upfiles/47520/C0F263746C474116A4880B3F4CE59171.jpg[/IMG]
[IMG]local://upfiles/47520/A13370B683FF4B86B8EF5EC65FD4C498.jpg[/IMG]
[IMG]local://upfiles/47520/5803A5B052574CD593CEB66E9E929496.jpg[/IMG]
[IMG]local://upfiles/47520/1C9D7FDE557E436FBAF224802D61B235.jpg[/IMG]
More Pics
[IMG]local://upfiles/47520/1EA11875AAB5410FAA98B86A30A7D38D.jpg[/IMG]
[IMG]local://upfiles/47520/EA2D34A1983546F6ABDFF76BBB308E57.jpg[/IMG]
[IMG]local://upfiles/47520/A5C9FC9811964177832DD157820C0EDD.jpg[/IMG]
[IMG]local://upfiles/47520/0A0C2E9D3B3B474FB428C7B85DE0845D.jpg[/IMG]
[IMG]local://upfiles/47520/79ABF54A729E4E6182A5A9385E385639.jpg[/IMG]
Matt's 95 Stang
10-05-2015 07:16 AM
KingRando
10-02-2015 08:06 AM
