Rear glass leak, HELP
I have a 71 coupe and the rear window leaks horribly.
I had a glass place install a new gasket and they put urethane on the inside of the gasket where it meets metal b/c there was a void in the pinch welds where the headliner meets the rear window in both top right and top left corners. It still leaks, if not worse than before. Any thoughts? The body is in good shape.
The glass guy suggested putting silicone around the seal and the body on the outside before reinstalling the chrome around the window. I'm afraid this will cause rust.
Please help. I am taking a road trip with it in about two weeks and would like it to be water tight.
Thanks
Tom
Thanks
Tom
you do not use urethane on the gaskets...you you need to pull it apart and seal it with Bedding and Glazing compound...
http://www.autobodytoolmart.com/3m-a...9-p-10389.aspx
bedding compound
This goes between the gasket and the body correct?
And it should fill any voids?
Then the question is do I take it back to the same guy, or find some other glass person....
He was very kind and eager to help, just not familiar with old mustangs... or perhaps older cars in general.
Thanks!
Thanks!
well if they are a glass place they should have know not to use urethane on a gasket....have them pull the glass and reseal it correctly with the Bedding and Glazing compound...it goes in between the glass and seal and the seal and body...
Thanks for the help.
No one where I'm at knows about the bedding and glazing compound. The auto body supply store only sells butyl rope and urethane in calking tubes. Is the glazing compound thicker? Why wouldn't the urethane have worked?
Well I only paid him $17 cash so I'm not out much and he was the owner... He was helpful just didn't know his stuff about old cars. I'll try him again, but if that fails I'll go elsewhere.
urethane is a hardening glue.....the B&G is a non hardening sealant same stuff the water shields behind your door panels are glued on with....as for where to find it the guy above said hes seen it at napa i have too...or you can order it from www.abtm.com
Thanks for all the help. Took it to a different glass place that works on lots of old cars. They pulled the glass and gasket and used b&g on it. The headliner apparently is attached by the pinch weld which caused some of the problem. Also there are points where several pinch welds come together that create a big gap. When she gets a new paint job I'll have to get a body guy to "smooth" out some of the seams so that it seals better.
It still leaks, but much, much less and only into the trunk where the factory drip rails are. This is acceptable for the time being.
Plus, since this glass place noticed the headliner and weld problems, they couldn't guarantee the work, so they didn't charge me! I gave them two tube of B&G compound for their efforts.
