289 stuck distributor bad
I know there are lots of threads on sites for loosing a stuck dist, I have sprayed mine for days and tapped and knocked with no luck at all. My question is can I tear out this Dis from the top and replace. Im fairly mechanical minded.
Ive always just put some vice grips on it and muscled it loose. But if you still cant get it to come loose, put some heat on the aluminum part at the base with a propane torch, then shock it with some loctite freeze and release.
