Autolite 4100 troubles
I have a 1966 mustang 289 with a C4 automatic. The carburetor is an Autolite C5ZF-F mounted on a ford 4 barrel intake. The engine was running very rich to the point of spitting chunks of carbon out the exhaust. I tried to reset the float level to the .906 wet setting but could not get it quite that low. It was still running rich so I changed to the jets from a 48 to a 46 on the primary and from a 58 to 56 on the secondary. Now my troubles.
1. When I start the car with the engine cold it will not keep running without making several attempts and revving up the engine. It then seems to idle a bit slow. Choke appears to be operating properly. Did I lean it out to much? Used to start up and keep running.
2. The engine idles roughly. Changed out the plug wires to another set I had with no noticeable difference. The rotor and cap are new. I find no vacuum leaks .
3. I noticed after I shut off the engine that fuel on the primary side of the carburetor was going into the engine.
Any help would be appreciated.
Problems 1 and 3 solved by resetting floats to dry specification and putting stock jets back into the carburetor.
Problem 3 remains unsolved. Are there errors that can be made rebuilding the carburetor that would cause a rough idle?
Thanks
Thanks
a lot of people go to the 351w firing order because it is a better order to use for reduced engine harmonics etc
Have you checked the fast idle cam for the choke? It should have two idle settings. When the choke is engages the idle will be higher, not just from the closing of the choke but from the butterflies being cracked a little more using the fast idle cam.
