throtle return spring
Old Apr 18, 2006 | 12:58 PM
acidrain088's Avatar
acidrain088
Default throtle return spring
i rember a light spring on my carb when i removed the engine over 6 months ago. i hooked the carb up to the engine that is now in the car along with all the throttle linkage. i press on the gas peddle and it doesnt feel right. it feels like it it is way to easy. is this because there is no vacume or because im using a spring for the throttle thats way too weak.
Old Apr 18, 2006 | 01:19 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: throtle return spring
Are you sure you have the spring located in the right place?
Old Apr 18, 2006 | 01:26 PM
69boss429's Avatar
69boss429
ORIGINAL: acidrain088
There should actually be a double spring,1 light,1 slightly heavier.
[IMG]local://upfiles/25247/B1D2D95DED61492FBC3D3C3D818FE424.jpg[/IMG]
Old Apr 18, 2006 | 01:59 PM
acidrain088
where should it be locaded. on the part of the carb where the throttle linkage goes and where else?
Old Apr 18, 2006 | 04:45 PM
DrBob67's Avatar
DrBob67
You did not mention what year or type of carb you have. If this helps I have a photo I took before I took off my carb that shows the linkage and the spring. It is a 67 289 with a two barrel carb. I have found that it has been helpful to use my digital camera to take photos before dissasembly.
Bob Johnson
67 coupe
San Diego
[IMG]local://upfiles/34456/E1481E6B5A494A0BAE2772DF365582A7.jpg[/IMG]
GimpyHSHS
19
Dec 19, 2023 01:12 PM
CS2007
Jun 25, 2019 09:45 PM
Thunderball
15
Nov 22, 2015 11:49 PM
mungodrums
Sep 28, 2015 10:54 PM
