Rear End Confusion
Rear End Confusion
Well started collecting all the data i needed for the rear end rebuild. Then hit some interesting stuff. The rear end is a 9" And the tag states that it has Traction Lock because it says 3L25. The Ratio is 3.25 gears and the L means Traction lock. What is traction lock? Because right now only one tire will spin. And I already have a posi unit to put in there.
RE: Rear End Confusion
Yeah that makes sense. So what do you suggest? Take it apart and check if there is a Traction Lock setup in there? How would i know if there is (my step dad said something about some bolts being recessed) And if there is get the clutches replaced? Or put the Posi i picked up (would need new bearings, dont even know its condition, garage sale item) in there instead.
Thanks again. And the whole not original to the car thing is very open, it was put together with some 70 or 71 donor car parts such as the tranny, fenders and other things.
Heres some more questions
1. How would i be able to tell if there is a traction lock in there and the clutches are just worn? (if i take it apart what would it look lke)
2. And If the clutches are bad in the current one is it possible to get them replaced or just install the other posi i have? (be in mind i dont know the condition of it either)
There are physical differences between an open differential carrier and a Traction Lok carrier, so yeah if you take it apart you can visually determine if it is a Traction Lok carrier or not. If you're only getting one wheel action, then it may need a rebuild if it is a Traction Lok, or chances are some time in the past someone replaced the carrier with an open carrier if they really didn't know what they were doing, or maybe just needed a quick fix. Check out this website:
http://www.kevinstang.com/Ninecase.htm
It describes the differences between all the 9-inch housings and carriers including how to tell if you have a Traction Lok or not. The quickest way to look at it and tell is to drop the third member and take a look at the carrier where the ring gear bolts are. If the bolthead spacesare cut in to the metal, then it is a Traction Lok. If the carrier is flat where the bolt heads are, then it is not a Traction Lok.
If it needs to be rebuilt, you can buy all the parts you need from places such as Summit Racing online. They carry clutch paks for Ford Traction Lok differentials.
FYI it's not hard at all to open up a Ford 9-inch rear end. It's the easiest and quickest rear end to work on. Just remember you have to pull the axles out of the carrier before you can remove the third member assembly to look at the carrier. If you need some help on a step by step procedure on how to disassemble it let me know.
