Engine swap w/radiator swap - 1967
I am in the process of replacing my worn out 289 with a 351W in a 1967 coupe. I would also like to put the 390 radiator in, but not sure if all of the mounting points are the same or not, or even if the physical dimensions will allow it. Does anyone else have any info on this swap that might help me out? I tried searching, but apparently I am inept at searching the forums as I never got any results back.
RE: Engine swap w/radiator swap - 1967
Look in catalogues for part number patterns. A BB rad might be wider than a SB one. Make sure you keep the correct sides for the hoses too. I'm sure better advice will follow.
If the 390 unit fits, use it.
Or, have your original recored and have the lower hose neck relocated to the drivers side.
Your local radiator shop has a book that shows all of the mounting patterns and dimensions. A 69 351W car would be a good starting point.
Spend what $$ you must on a good radiator. It's a critical component and if you neglect it you will be sorry.
09-01-2015 08:16 PM
