Made allot of progress this weekend!
Made allot of progress this weekend.. Installed the headers, Valve covers, Alternator, pulleys, Fan, Radiator, Fan shroud and the water pump. I still have a bit to do like all the wiring, tranny lines, fuel pump, carburetor and all the tranny linkage
[IMG]local://upfiles/26659/2308D14BA83B46F5BEB2EF243B51778B.jpg[/IMG]
[IMG]local://upfiles/26659/137BE63BC62C447E92931F8F03775D22.jpg[/IMG]
RE: Made allot of progress this weekend!
Actually that's a AOD transmission pressure gauge With an AOD the tranny pressure is VERY important and I needed to have a gauge to check it so, for $15 I figured what the hell. It's adjusted using the kick down cable.
From what I found at an idle and in natural there should be 0 - 5 psi and should not be any more than 30 psi for a firm shift.. Do you have anything different?
ORIGINAL: THUMPIN455
Thats the best way to set the TV.. do you know what the pressures should be? Can get the info if you need it..
09-27-2015 03:16 PM
09-25-2015 09:06 AM
