carbureted pcv system
Dose any one know how to hook up the pcv systm on a carbureted car? Mine is hooked into the vach tree and i dont think its hooked right [:'(]
RE: carbureted pvc system
it hooks to direct manifold vaccum and its PCV(positive Crankcase Ventalation) not pcv(poly vynl chloride)
thx, how and were do i hoook it 2?
If it is hooked to manifold vacuum, and it sounds like it is, then it is correct.
here some pices
[IMG]local://upfiles/43346/4EACD74801514EF1B75220429185F5EB.jpg[/IMG] [IMG]local://upfiles/43346/F993D34ADB80455CAA50694305B40B22.jpg[/IMG] |
Ha ha! That is hokey!!! You should never T off your PCV. I assume the black hose goes to the brake booster. The booster and the PCV should go to the manifold. The after market manifold you are running should have ports in the back to make both work. Look and see if someone put plugs in these holes in the manifold. If so run your booster and your PCV into the manifold with there own hose and fitting.
could that be y oil is comeing out from my intake bolts??
Hey! Is that a freaking fox body?
its a Victor Jr Intake
yep , the boys on the 5.o dont mess with may carbs
