**** maaco!!!!!!!
Old Dec 9, 2006 | 01:18 AM
ideal_mustangs's Avatar
ideal_mustangs
Default RE: **** maaco!!!!!!!
The thing is though, if they are only getting 1000 for the paint job, then they aren't going to spend nowhere near as much time doing the prep work as they would if they were getting 5000. They are running a business and trying to make money and can only put in so much time to it for the amount of money you pay.
Old Dec 9, 2006 | 01:52 AM
Halz5's Avatar
Halz5
On my 66 Chevy, the paint alone (and primer) was more than 1000.... the moral of the story is to not go to maaco unless u have a rice burner or an 80's mustang which is like fords version of a ricer
Old Dec 9, 2006 | 01:58 AM
bradleyb's Avatar
bradleyb
could be a couple of things - poor surface prep in that you have foreign material on the surface and could also be that you have some chemical issues which would again be surface prep if they didn't get the sealer coat right.....so I would say that these types of issues would squarely fall under the heading of "prep and paint".
That said, Maaco is **** and for $1,100 bucks they are going to mask and paint - for this much money, a real paint shop couldn't even really do a "prep and paint" that was really just mask and tape. I am really surprised that you had a good experience with them before
Old Dec 9, 2006 | 02:07 AM
david01130's Avatar
david01130
Thanks for the comments and info. Could someone find me some good info or proof that the prep work caused the cracking and not my bondo work? It is the prep work that caused the cracks right? Or is it my bondo work? If I could get some good reasons as to why there are such large cracks in the paint I might be able to convince them to reshoot it. or at least get something out of them. I wish I had my camera with me to take some pics. I thought bondo only cracked over time?
To summarize the paint job there are basically very noticible cracks in the paint where I had done the body work. There are cracks on almost all the areas where I did the work too not just one area. So I am assuming it is the prep work.
So does anyoen have any proof or evidence that this is prep work?
I know I cant expect a perfect paint job but when I pay for prep work I expect there to be no cracks and **** coming through the paint.
Old Dec 9, 2006 | 06:09 AM
andrewmp6's Avatar
andrewmp6
i use to work at macco here we used napa 8 bucks a gallon paint it smelled like house paint no joke. we didnt even sand the car just used a green scrub pad
Old Dec 9, 2006 | 10:11 AM
Cannonball888's Avatar
Cannonball888
ORIGINAL: andrewmp6
We need to get you on 60 minutes
Old Dec 9, 2006 | 02:37 PM
Yonco's Avatar
Yonco
uh oh... -Jon
Old Dec 10, 2006 | 12:17 AM
stanging's Avatar
stanging
They could have used the wrong type of thinner for the conditions or too much hardner, or layed it on too thick, are there other cracks not in a bondo area?
Old Dec 10, 2006 | 12:23 AM
david01130's Avatar
david01130
not sure. I was thinking about that and I think I might have seen a small crack on the deflector. There was also rain drops all over the car because it was outside so I didnt get a good look at the whole car.
Old Dec 10, 2006 | 12:31 AM
stanging's Avatar
stanging
As far as the bondo areas, it sounds as if the thinner or the paint attacked the bondo.
